APK block with ABF head
Vonn
Registered for: 2 months
Post by Vonn »
Hi guys,
I'm looking to swap an abf head onto my apk block. Are the any modifications I should do or will it be a direct bolt on?
Also, I do plan to turbo the motor, is there anything I should know about taking on this type of project?
It's my first time taking on a project like this so any help is appreciated🙏
Ry@n
Registered for: 13 years 9 months
Car Model: VW Caddy 2K 2.0 8v
Re: APK block with ABF head
Post by Ry@n »
Hi Vonn,
It can definitely be done, I was considering doing the same setup but decided to go the fsi head swap.
You can have a look here for the entire build https://www.vwvortex.com/threads/mk4-mk ... id=4001222
The APK, AEG & AZG engines are identical.
2008 VW caddy panel van 2.0 8v
2012 Nissan Pathfinder 2.5 Dci Le
Vonn
Post by Vonn »
Howzit Ry@n,
Thanks bro, I'll give it a shot. Also, would I have to run standalone management to get the turbo to run?
Ry@n
Post by Ry@n »
Yes, definitely standalone
Vonn
Post by Vonn »
Thanks man, much appreciated.
