2 litre 8 valve turbo
amaniveld
Registered for: 7 years 9 months
Post by amaniveld »
Good day
Hope everyone is well? I am considering turbocharging my mk3 2 litre, 8 valve (AGG) I know the easiest route would be to replace the motor but the reason I'm wanting to do this is because the car basically stands a lot more than I should be driving it as I use a company car. Anyway the current setup I have is a AGG block with APK crossflow head, Rowland intake and Toyota Itb's. I'm going to remove the motor (hopefully soon) and I'd like to fit all the proper parts with this build for reliability SO MY question to you guys is what Pistons (wiseco if possible) should I use, where can I have a intake manifold made up and whom and where in Cape town can I buy all the odds and ends Ill need? This is a long term build so I'm in no rush, I am trying to get all the parts together in the mean time.
I hope this doesn't bore you guys or get me into trouble as I take it this has probably been asked 1000s times :shock:
Thank you
