AvesshenG wrote: ↑Sat Jun 24, 2023 1:50 pm
Howsit Guys ,
I'm looking at doing the timing chain on my VW Mk7 GTi 2015
I want to use OEM parts, tried getting a quote on parts from the local dealership but they weren't able to list everything or didn't want to.
For instance their quote only had two chains when the car has 3 different timing chains ,I could see I wasn't going to get helped.
Is there a specific part number for the full timing chain kit?
That way I can order all parts needed as a kit to ensure we have all parts when we open up to do the job.
Its the NON performance pack so the CHHB engine.
Regards
If you want to do it properly:
Part Number____Description_____________________________________Size__________Quantity
06K109158A______timing chain____________________________________________________1
06K109158AD_____timing chain____________________________________________________1
06H109467AR_____chain tensioner_________________________________________________1
06K109467P______chain tensioner_________________________________________________1
D 154103A1______sealant_______________________________________100G_____________1
06H109469AQ_____slide rail______________________________________________________1
06K109469N______slide rail______________________________________________________1
06H109469AH_____slide rail______________________________________________________1
06K109469M______slide rail______________________________________________________1
06H109509P______slide rail_______________________________________________________1
06H109509Q______slide rail_______________________________________________________1
N 10765401______Hexagon socket flat head bolt___________________M6X35_____________2
N 10156206______Oval hexagon socket head bolt___________________M6X30____________4
06K115225C______Drive chain_____________________________________________________1
N 10706901______Hex collared bolt______________________________M10X55___________1
N 91029602______double stud with hexagon drive__________________M10X55/M6X12_____1
N 91204001______Hexagon bolt__________________________________M8X50____________1
N 10552404______Hex collared bolt______________________________M12X1,5X70________2
N 10701501______Socket head bolt with inner multipoint head_______M10X65___________3
06K103583_______Seal___________________________________________________________2
06K103483_______Seal___________________________________________________________1
D 174003M2______Silicone sealant________________________________80ml_____________1
06K109210AF_____timing case_____________________________________________________1
D 176501A1______Silicon sealant_________________________________50ml______________1
N 91096702______Oval hexagon socket head bolt___________________M6X16____________15
N 91232801______Socket head bolt with inner multipoint head_______M6X52_____________6
