Polo 9N3 wet rear footwell
- Car Model: Caddy MK3
Howsit so after some heavy rains last night I noticed a puddle of water in the rear footwell behind the drivers seat. Soaking wet carpet. The rest of the interior is bone dry and no evident leak from the sunroof. Windows closed tight and rubber around door is vas. Anyone with similar problems I would appreciate some input. Thanks
TDi
- Car Make: VW, duh...
- Car Model: Stuff
Re: Polo 9N3 wet rear footwell
Check the round rubber seals under the carpets and insulation.
Easiest would be to jack the car up and look underneath.
Or remove back seats, carpets, insulation and check. You will have to do this any way to make sure everything dries properly.
2012 Suzuki Hayabusa
2021 Aprilia RS660
2021 Aprilia RS660
- EX-DOHCTOR
- Registered for: 20 years 7 months
- Membership No: 712
Are the sunroof drainage channels clean and clear of debris?
- Registered for: 7 months
Hello, did you ever figure it out?
