Clutch pedal hard and difficult to get gear
Our experienced team offers you competent advice and the corresponding services. With our many years of experience, we help you to interpret the error codes and the measured values stored in the control units.
Joshua92
Registered for: 5 years
Post by Joshua92 »
Hi guys,
I have a issue with my clutch pedal, (mk1 golf 1.4 carb, 020 box)
So after i replaced my release bearing my clutch pedal is hard and difficult to get gear, when i removed the release bearing i saw that my rod was burnt aswell assuming it could be of to much friction, i replaced rod and same happened dont wanna drive so cause scared i could damage my pedal box, so i dropped the box and it seems fine thrust plate looks good also, so im thinking of replacing clutch and pressure plate, could that maybe be the problem? And i replaced clutch cable but still so
Need help asap
Regards,
Joshua
