mk1 ffz gear ratio
Our experienced team offers you competent advice and the corresponding services. With our many years of experience, we help you to interpret the error codes and the measured values stored in the control units.
Sumeshmk1
Registered for: 5 years 2 months
mk1 ffz gear ratio
Post by Sumeshmk1 »
hi guys
what is the easiest way to change the gear ration on a FFZ Gear box 3-4-5.
the gear box is currently from a 1.4i
regards
Sumesh
Car Make: VW, duh...
Car Model: Stuff
Re: mk1 ffz gear ratio
Post by Jetta2 »
Easiest? Remove the current gearbox and fit another one that has the ratios you want.
Gearbox has to be removed, stripped down, gears swopped out, and put back in the car any ways if the ratios need to be changed. Simplest and easiest way is what I said in the first line.
2012 Suzuki Hayabusa
2021 Aprilia RS660
Sumeshmk1
Post by Sumeshmk1 »
that I understand clearly but I actually mean what gears would I need and from which gear box would. be recommend
Car Model: Stuff
Post by Jetta2 »
You should asked that then.
More info is required before anyone here can give advise.
What car is it?
What gearbox code is in the car now?
What are you expecting from changing gearbox ratios?
What mods have been done to the car engine wise that would prompt a ratio change?
2021 Aprilia RS660
chucker02
Car Model: Citi ADY
Post by chucker02 »
An FF box is the one you want, I think 1-2-3 is the same as the FFZ but 4 and 5 is longer
1971 VW beetle
Sumeshmk1
Post by Sumeshmk1 »
ok currently I have a 1.4i velocity with the stock ffz gear box
I have 2l bottom end with a 2l cross flow cylinder head ( head was completely done by vandelinde ) .
I am using a set of throttles , with a stock FFZ gear box I will get of the line quick but from 3rd gear down it will get lazy so therefore I wanted to change the ratios of the gear box to carry the car over 400 m , I want it to have a decent balance through the gears
chucker02
Car Model: Citi ADY
Post by chucker02 »
Then call 8v performance when they open again and tell them what you want. They will sort you out with a perfect gearbox
1971 VW beetle
missioner
Car Model: '87 MK1 Golf Citi
Post by missioner »
chucker02 wrote:An FF box is the one you want, I think 1-2-3 is the same as the FFZ but 4 and 5 is longer
This ^^^^^^^
100% agree
