Re: mk4 water use
Re: mk4 water use
Hi guys my golf tdi water level is still dropping after replacing waterpump new waterbottle termostat flange and I dont see any lekkages on engine. However my wayerlevel is still dropping although slowly
- Car Make: VW, duh...
- Car Model: Stuff
Re: Re: mk4 water use
M9ds, please move this to the correct section.
2012 Suzuki Hayabusa
2021 Aprilia RS660
2021 Aprilia RS660
- ICE King
If not visible leaks outside the car , can be:
1.leaking on the heater unit inside the car
2.Mixing with the oil
Have you carefully gone through the visible parts of the cooling system?
