RCA leads - advise/feedback
Gti3
Post by Gti3 »
Has anyone used the below RCA leads and can you recommend them. It is to be installed in An Amarok from Pioneer AVH-205BT head unit to Star Sound 4 channel Amplifier. 1 set will be for front stage i.e. Kicker 6.75 inch Splits and the other set will be for the subwoofer i.e. Kicker 8inch 2ohm SVC
This is the lead i'm looking at :
https://www.soundmatch.co.za/Products/P ... oaxial-rca
If you have any other suggestions around the same price that will be welcomed as well.
2020 MK7.5 GTi DSG
EX:2013 MK7 TDi HIGHLINE DSG
EX:2010 MK6 GTI 6MT
EX:2006 Ibiza Cupra TDi
EX:1993 Golf 3 Gti
EX:1970 Beetle 1600 Twinport
theunis.visser
Registered for: 7 years 7 months
Car Model: Mk5 Golf GTI
Re: RCA leads - advise/feedback
Post by theunis.visser »
Stinger is quite a big brand in the USA. Another big one is Phoenix Gold.
Gummi
Registered for: 6 years 10 months
Car Model: Mk4 Jetta V5 AGZ
Post by Gummi »
Just buy it man. It will work.
This bothers me. They mention "Audiophile grade performance" IF anybody here is in to SQ, whether it is at home or in car, then they wil ltell you otherwise. Even if it was, your amp would be the downgrade. So buy it and use it. Its good enough.
ICE King
Post by ICE King »
Not the best but will do the job , you get what you pay for.
amstel18
Car Model: Tiguan Allspace
Post by amstel18 »
ICE King wrote:Not the best but will do the job , you get what you pay for.
Well with the starsound amp, he may as well buy some ellies RCA's from pnp
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
TDIFlava
Registered for: 7 years 10 months
Post by TDIFlava »
amstel18 wrote: Thu Oct 11, 2018 12:51 pm
I think you can get cheaper one's from the flee market that will do the job.
Audi A3 8p TDI (Decat, twin S4 tail pipes, 17" rims, SQ sound system) (103kw/420nm)
Polo Classic 9n3 1.9 TDI (Decat, SQ sound system)
Golf MK1 aka Gravedigger
Citi Golf 1.4 Sport (RIP)
ICE King
Post by ICE King »
lol
@ Op...good set comes with a premium but will be worth it.
I once cut up and a "cheap" set of RCA's and found that in order to keep cost down , they'd use a single 50% copper strand which was rolled around single strand of cotton, end to end.
While this may work , It's affects quality sound and resistance , instead of getting the full pre-out voltage from HU to amp , had a loss of voltage resulting having to turn the gain on the amp higher and meant distorting.
Thats one issue , the other was crappy RCA terminals that can't make a secure connection on the HU/amps output/inputs.
Killerwatt
Registered for: 17 years 1 month
Car Model: S3
Post by Killerwatt »
Been a while since I shopped for rcas, but those will be fine. A 5m length sounds like overkill for an amarok though. You will probably find better 3m rcas for the same price.
The thickness of the conductor has little effect on the performance of the cable. Most amps have an input impedance around 15kohm. A 5v preout will result in a 0.00033A current, effects of resistance is negligible.
Capacitance of the cable is the only real parameter that affects the sound.
What you pay for in a good rca is the connectors and multiple layers of shielding.
Gti3
Post by Gti3 »
TDIFlava wrote: Thu Oct 11, 2018 1:08 pm
I am using the StarSound amp for now as it was given time for free. I will change the amp in time, however I don't want to have to buy RCAs again and have to route them again. On the other hand, I also dont want to spend 1k on RCA leads as there comes a point where the difference/value/benefit cannot be told to the average ear. I just need something that is quality, that plays clear and is long lasting.
2020 MK7.5 GTi DSG
EX:2010 MK6 GTI 6MT
EX:1993 Golf 3 Gti
Gti3
Post by Gti3 »
Killerwatt wrote: Thu Oct 11, 2018 4:00 pm Been a while since I shopped for rcas, but those will be fine. A 5m length sounds like overkill for an amarok though. You will probably find better 3m rcas for the same price.
Thanks for this feedback., Helps with what to look for.
2020 MK7.5 GTi DSG
EX:2010 MK6 GTI 6MT
EX:1993 Golf 3 Gti
