Polo not starting after rear main seal replacement
AndreBestbier
Registered for: 8 years
Car Make: VW Polo
Car Model: 2007 Polo trend 1.6
Post by AndreBestbier »
Hey guys
I replaced the rear main seal on my 2007 VW Polo trendline and now struggling to get it to start.
It turns over but does not start. I took gearbox off again to check oil ring timing mark against TDC as i did not align them the first time....but stil no start.
Seal was leaking oil thats why i replaced it.
Some advise please. Thanks
amstel18
Car Model: Tiguan Allspace
Re: Polo not starting after rear main seal replacement
Post by amstel18 »
Original part or pirate?
Heard of some bad quality pirates where the sensor in the seal doesn't read properly...
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
EX-DOHCTOR
Registered for: 20 years 7 months
Membership No: 712
Post by EX-DOHCTOR »
I have a brand new one with a new input shaft seal:
Let me know.
AndreBestbier
Car Make: VW Polo
Its a Uniseal rear main seal without sensor. Bought at Masterparts.
I screwed the old sensor back on there seeing that the seal was only leaking and had no faulty sensor problems...
Oil ring hole was also aligned with the hole/mark on the housing while the crankshaft was on TDC....
What else am i missing or doing wrong?...
Registered for: 22 years 10 months
No I recon just take that OE that is on offer.
Ashveer03
Post by Ashveer03 »
The new seal is probably not a pickup type seal..?
The oe seal is at a steal, u rather fit that with the new sensor as panic suggested
AndreBestbier
Car Make: VW Polo
What you mean by a pickup type seal?
Ashveer03
Post by Ashveer03 »
Sorry I put that wrong. The oil ring as u referred to is the pickup (a tin type of ring thats magnetic) and that should fit over the teflon seal thats built into the housing.
Did u buy the seal together with the pickup ring and the little plastic alignment goodie? Or did u just buy the seal?
If i remember correctly, the pickup steel ring must be a certain distance away from the crank sensor (I cant remember the exact distance, u can checkup on google) if the distance is too much or too less the signals will be interupted which could cause a no start condition. And thats the reason these seals must be bought together with the pickup ring.
When it comes to these cars I always only buy victor reinz as it comes in a set (seal, pickup, sensor) and it costs R1300. Another reason we suggested u buy the oem set that the guy posted.
Ashveer03
Post by Ashveer03 »
Make sure not to damage the pickup when installing, it requires a tool to fit, but can be fitted with a mallet and some care..
Also note that the hole on the pickup does not line up with the hole on the seal housing, but with the little dimple on the left of the hole on the seal housing..
AndreBestbier
Car Make: VW Polo
I bought the seal with housing and pickup ring and the plastic alignment ring...but with no sensor. I screwed on the old original vw sensor that i took off...
Installed it very carefully with no alignment tool and only with the plastic alignment ring and some screws while tightning it and making sure not to damage the seal. So thats fine.
You say that the hole on the pickup should NOT align with the hole on the seal housing?....because i aligned the two holes together. Found the same alignment and method on the internet....
What if i use the same pickup ring and sensor from the old vw seal that i took off and install that onto the new seal, and then make sure of the correct clearance between the ring and crank sensor? Will that make a difference? Will that be more compatible..
You can mess around for days trying to make that work or simply do it once by buying the right thing. These things are extremely finicky and instead of multiple times taking the box off while trying to save a couple of 100 bucks just seems silly to me.
Ashveer03
Post by Ashveer03 »
Im sure u could use the old pickup ring again as long as its not bent and stuff..
And yes the holes MUST NOT be aligned together. The hole on the pickup ring must be about the 11 o clock position where u will see a small dimple on the rear main seal housing
Ashveer03
Post by Ashveer03 »
If u look closely at the pic ex-dohctor posted, u will see a white mark on the seal housing around the 11 o clock position and below the white mark theres a small cut away. Thats the dimple im talking about
Ashveer03
Post by Ashveer03 »
@OP panic is correct. If the pickup is a little of position the car will behave weirdly. Its very important for it to be in the correct position and u should buy a seal kit that comes with the alignment tool
AndreBestbier
Car Make: VW Polo
Thanks guys for the advice.
Tried the old sensor and old oil pickup ring together, put them on the marks as said, and all working and starting fine again.
But i will definitely if i have to replace a rear main seal again spend more money and buy a complete original VW seal kit and do it right first time. Not worth the hassle lol.
Cheers
Ashveer03
Post by Ashveer03 »
Cool.. I doubt u will get another oem seal at that price, next time if not oem, use victor reinz been using them for years with no problems at all
VR is an OEM supplier. So the item in the OE bag is made by them anyway.
Ashveer03
Post by Ashveer03 »
Oh ok didnt know that
2Xxx
Heya dohctor do you still have the seal for sale ? mvdsandt@gmail.com
Post by 2Xxx »
EX-DOHCTOR wrote: Wed Jun 14, 2017 3:30 pm I have a brand new one with a new input shaft seal:
Let me know.
ngwetjanat@gmail.com
Post by ngwetjanat@gmail.com »
Hi I need one please hook me up 👆, I bought one without a sensor now my car is not starting so I need a complete one
0834679855
Blessing96
Post by Blessing96 »
I’ve got a polo 1.2 tdi bluemotion the pick ring has three notches. I put the car on tdc and put the first notch straight facing the sensor did i do it correctly. I don’t have a lining tool and my car is a three cylinder
JayGrey
Registered for: 1 month
Post by JayGrey »
AndreBestbier wrote: Sun Jun 18, 2017 8:46 pm Thanks guys for the advice.
Cheers
HI GUYS,
I see AndreBestbier was able to use old ring and old sensor with new aftermarket seal. I am also about to put in the seal but I want to avoid taking gearbox out again if it's not right so I want to make sure. For the timing it was said that it doesnt line up with the hole but rather the dimple at 11 o clock of the housing but when I took my engine and gearbox apart I made sure to set the crank to TDC and I made not of where the hole lines up and I saw that it lines up with the mark/dimple just underneath the hole at 12 o clock and it did not line up with the dimple at 11 o clock. So to me it would make sense that it goes back the way it came off? Why cant we line it up with the mark made at 12 o clock? Also what is the distance between the sensor and pickup ring?
