*** Advanced File Service for 2.0TFSi engines ***
* 3bar MAP sensor calibration
* 200bar fuel rail pressure sensor calibration
* Flaps off + cold start fix
* RS4, RSR and other special injectors perfect calibration with injectors lag optimization also
* Totally disappearing of the "smoking" effect of RS4 injectors
* MAFless ECU transformation
* MAF case up to 100mm calibration
* Camshaft timing optimization for improving Turbo spool and fuel consumption
* Flaps optimization for better low-end toque and fuel consumption in City mode
* TTRS LPFP calibration to work with the stock PWM without any issue and engine shut-off
* Knock control recalibration dependent from cylinder/piston clearance and noise
Full big turbo support normal or extreme tuned and guaranteed excellent engine working as a factory car
Bosch MED9 tuning features
- RevLimit SA
- Car Make: seat
- Car Model: Leon Cupra
- Car Make: SEAT
Re: Bosch MED9 tuning features
Some really good features here eiers
You need to add handheld flasher and remote logging to that next
- Colonel
- Car Model: Golf VI R
- Membership No: 2023
Geez
Sounds epic! Anything for MED17 users?
- Car Make: SEAT
No, you not Bhai enough yet but you can get betterHoosier Daddy wrote:Geez![]()
- Colonel
Bhai shall be proud of it getting better... new clutchesDazzG_177 wrote:No, you not Bhai enough yet but you can get betterHoosier Daddy wrote:Geez![]()
- Hobbs
- Car Model: GTI MK5 - 248kw 530nm - KO4
- Membership No: 1848
Special features are available for all VAGs 1.4/1.8/2.0TSi with MED17.x.x ECU. In the future we will include PSA group also!Hoosier Daddy wrote:Geez![]()
version 1.0
* added userSelectable Launch Control
It works with ignition cut as softer feature or with antilag using timing retard
* FlatShift
It works via ignition cut or antilage feature also
* Shiftlight
EPC blinks 150RPM before the optimal shifting RPM in WOT condition
- Launch Control via MED17 is available for DSG and 6MT cars. For DSG cars it is necessary the
DSG Temic Launch Control deactivation== On development ==
* MapSwitching
* Knock failsafe
* lambda lean failsafe
* knock warning
* 3D N75 DC map for open loop boost controlling
* gear dependent boost control
Revlimit team
MK5 GTI
GTX30
Forged motor
power uknown
GTX30
Forged motor
power uknown
