Help with Revo Software identification / possible removal
- Registered for: 13 years
- Membership No: 1838
Hi guys.
I drive a SEAT Ibiza Cupra TDi.. Recently fixed a boost leak with the expectation of sorting out my high fuel consumption.. but I ended up getting worse fuel consumption after the boost leak was fixed. Sitting at an average of 8l/100km now with light driving for about half an hour (no traffic just general suburban driving).
I need some help here, as I am supposed to have Revo Stage 1 software..
1) I need to check if my software is actually active on the car. It really doesn't feel like it.
2) I want to revert the ECU back to stock so I can use a back-to-basics approach of sorting out my high fuel consumption.
I went to the Zwartkops Revo shop a few months ago, and was told they can take the software off for me for free and put it back on for R500 as long as I have the proof of purchase, didn't do anything about it back then as the proof was with previous owner. Phoned this morning again and was told they can do it for me but it costs R350 to set it up?
Is it not possible for me to do this for free? Seems silly to pay just to see if the software is active and then remove it if necessary.
Any help appreciated.
Thanks,
J
Thanks,
J
- M@rk
- Car Model: 1.9 Tdi Sportline
- Membership No: 1776
Re: Help with Revo Software identification / possible remova
Hi bud sent you a pm you can bring the car to me and I will have a look and try and see if I can sort it out for you.
- Car Make: SEAT
- Car Model: Leon Cupra
Remove the battery terminals for 30mins or so.
Should revert the ECU back to Revo Stock code.
- M@rk
Does this work with the edc 15 ecu to?DazzG_177 wrote:Remove the battery terminals for 30mins or so.
- Car Make: SEAT
Cannot confirm bud if Revo built that into all their codeM@rk wrote:Does this work with the edc 15 ecu to?DazzG_177 wrote:Remove the battery terminals for 30mins or so.
- dazza
- Registered for: 17 years 5 months
- Car Make: VW and VW
- Membership No: 1327
Easy to check if the map is still "active" it should smoke significantly from around 3500rpm at full throttle. If it does not smoke much at higher RPM then it may be in stock mode. Car should actually be slightly better on fuel with the map vs stock, mine was anyway.
What area are you in I have an SPS device easy enough to check what mode it is in.
Darryn Van Rooyen
Current: 1987 Citi Sport 1.6
Current: 91 Citi Sport 1.3
12' MKVI GTI Manual
2009 Audi TT 2.0TFSI S-Tronic
08 RS MKV GTI DSG
09 ZG Ibiza Cupra TDI
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
12' MKVI GTI Manual
08 RS MKV GTI DSG
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
- M@rk
The car does have sw on it and it is active but the file is pap ...we ran some logs and checkd timing , injectors, maf and cleared some Dtc ,all was in spec but the boost was very low .
Grimmy can give more feed back if he wish
- dazza
What was peak boost? If its in stock mode the software will still be there but it will have stock settings, will PM him nowM@rk wrote:The car does have sw on it and it is active but the file is pap ...we ran some logs and checkd timing , injectors, maf and cleared some Dtc ,all was in spec but the boost was very low .
Darryn Van Rooyen
12' MKVI GTI Manual
08 RS MKV GTI DSG
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
12' MKVI GTI Manual
08 RS MKV GTI DSG
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
- M@rk
boost was at 1.55 bar but actual boost were very low we think the car was fitted with a gt1749va and wasn tuned for itdazza wrote:What was peak boost? If its in stock mode the software will still be there but it will have stock settings, will PM him nowM@rk wrote:The car does have sw on it and it is active but the file is pap ...we ran some logs and checkd timing , injectors, maf and cleared some Dtc ,all was in spec but the boost was very low .
- dazza
Stock boost roughly for that car thenM@rk wrote:boost was at 1.55 bar but actual boost were very low we think the car was fitted with a gt1749va and wasn tuned for itdazza wrote:What was peak boost? If its in stock mode the software will still be there but it will have stock settings, will PM him nowM@rk wrote:The car does have sw on it and it is active but the file is pap ...we ran some logs and checkd timing , injectors, maf and cleared some Dtc ,all was in spec but the boost was very low .
Darryn Van Rooyen
12' MKVI GTI Manual
08 RS MKV GTI DSG
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
12' MKVI GTI Manual
08 RS MKV GTI DSG
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
- M@rk
As I said its a soft tune .dazza wrote:Stock boost roughly for that car thenM@rk wrote:boost was at 1.55 bar but actual boost were very low we think the car was fitted with a gt1749va and wasn tuned for itdazza wrote:What was peak boost? If its in stock mode the software will still be there but it will have stock settings, will PM him nowM@rk wrote:The car does have sw on it and it is active but the file is pap ...we ran some logs and checkd timing , injectors, maf and cleared some Dtc ,all was in spec but the boost was very low .
Thanks for the help Mark
Atleast there was nothing "wrong" with the car which is what I thought... I see no answer from VAGTechnik though, quite sad.
Thanks to those who contributed.
- VAG Cafe
- Registered for: 20 years 5 months
- Car Model: RS3
- Membership No: 675
Hi dude
Apologies.
We aren't as active on the forums and respond as quick as we can via email.
With regards to your query, if you aren't the original owner of said car...we sadly have to charge for time spent on the car especially so when it goes to our workshop. R350 would be an hours labour rate.
Revo UK policy states that the original owner of the car is the owner of the software on the vehicle. If that vehicle is flashed to stock at any point and then sold to another customer, we have to charge the new owner for a new tune should he want the Revo software back on. We do however try our best to assist customers in this scenario and this is typically when we charge the R500 to reload.
If you are an existing Revo customer, flashing to stock and then back to Revo costs you the customer nothing. That is a value added service that we offer to our customers.
Shoot me an email should you need any further assistance shaun@revotechnik.co.za
Apologies.
