Need to do this as I have a globe or two blown so thought it would help others in the futureSkommel85 wrote:Amstel 18
Well i had help from Bosmossel TDI,
you open your boot and then pull the inside plastic cover away near the brake light in the middle
it sounds like your going to brake the thing but dont warry, we where pretty rough
with it and no brakesbut be carefull not to pull it to far, you dont want to bend it.
There is 2 screws that you will loosen you dont have to take the cover off because the screws are pretty close
to get to and presto the brake light is loose
Globe type: R955 W16W 12V - HIGH LEVEL BRAKE LIGHT BULB
Will update with photos when I have a chance.
