Using SPS to aquire ECU settings
- Sparkz0629
- Car Model: 2012 Polo GTI
- Membership No: 1768
Hey Guys,
For curiosities sake, i wanted to try get the current settings that are on the car.
So i start the SPS select software, plus the SPS into my pc via cable (switch set to "0" for communication), connect the SPS to my car, turn the ignition on, and click on "Acquire" under the ECU section.
The app then hangs for about 30seconds, and then returns the following error:
"ECU unrecognised, or not found."
Any idea why this would be??
TIA
Dex
TIA
Dex
Current: 2012 Reflex Silver 6R Polo GTI
[url=http://www.vwclub.co.za/phpbb3/viewtopi ... ead#unread]
2006 1.9TDi Sportline - 158.7Hp & 413Nm at K.A.R 19-05-2012
VWicked wrote: I could do 300km/h if I wanted but I don't trust my brakes stopping from that speed so as soon as i hit exactly 241km/h on my garmin i will tap off, generally it takes me me 6.9 sec to get there so I will just cruise the last 5 sec's to allow the car to cool down..
- Sparkz0629
Re: Using SPS to aquire ECU settings
bump
- chrispribs1
- Car Model: Polo GTI 6R
- Membership No: 1898
Hey Dex
didnt even know we could check that, did you manage to come right on this?
Current: 2014 Reflex Silver Golf 7 Gti, DSG
Ex: 2012 PGTI
Revo Stg 1
Ex: 2012 PGTI
Revo Stg 1
- Deranged_9n3
- Darth Vader
- Membership No: 1639
Does this not have to do with the benchflash ??
My Youtube Channel
Tiguan Track & Field 4Motion
Polo TDi RaceCar
GTB2260VZK
13.2 1/4mile @ ODI
Loud 'n Low, Rollin' Coal
Polo TDi RaceCar
GTB2260VZK
13.2 1/4mile @ ODI
- Ian_F
- Car Model: Voetswagen
- Membership No: 1846
You can download SPS program from http://www.revotechnik.com/sps/
Install on your PC.
Switch SPS to communicate with PC (cant remember which setting)
Plug into vehicle, and use USb to aquire...
happiness
Install on your PC.
happiness
- Sparkz0629
Hey Ian,Ian_F wrote:You can download SPS program from http://www.revotechnik.com/sps/
Install on your PC.
happiness
Thats the exact process i used, and i get the error mentioned above.
- Sparkz0629
Hey Chrischrispribs1 wrote:Hey Dex
You should be able to use this to see what settings are currently on your ECU.
Nah, no luck yet...
How's the car running?
- Sparkz0629
It was bench flashed to start with, but should be sorted out...1FlyTDI! wrote:Does this not have to do with the benchflash ??
- Ian_F
Maybe the 6R cannot do this...Sparkz0629 wrote:Hey Ian,Ian_F wrote:You can download SPS program from http://www.revotechnik.com/sps/
Install on your PC.
happiness
I know it only works sometimes on my car...
- chrispribs1
Sparkz0629 wrote:Hey Chrischrispribs1 wrote:Hey Dex
Nah, no luck yet...
As usual anyothe thing that doesnt work on the 6R, sadly. Car is going great..really setting in now. I threw in a K&N filter..feels even better now on throttle response and late end torque. Also tested with some NF Ultra...wow what a awesome difference. Not in the hot temperatures though..my car hates hot days now that it has SW.
Ex: 2012 PGTI
Revo Stg 1
Ex: 2012 PGTI
Revo Stg 1
- Shaddow
- Car Model: Audi TT-S
- Membership No: 1957
Must be a 6R thing - it works perfectly on my car. And i have the Audi white MFD, which is the one that is normally the most buggy and difficult to get to work with any external gadgets.
Maybe ask someone else to try their pc and sps to acquire it... Where in Jhb are you? If you're close, I can try for you.
2012 Scirocco DSG K04
CPi Tuned!
12.3@184 - Tuner Wars (Nov 2014)
245wkw 564Nm
2008 Audi TTS S-Tronic - Revo 2, DP (12.9 @ 178 - Tarlton S2S)
2008 Golf 5 GTI DSG - K04 APR Tuned (13.6 @ 175, street tyres - Tarlton S2S)
CPi Tuned!
245wkw 564Nm
- VAG Cafe
- Registered for: 20 years 5 months
- Car Model: RS3
- Membership No: 675
hey guys,
Sorry for the late reply. I'm currently on leave until the 7th so hardly have had time to pop in to check the forum. The 6R GTI does haggle a bit when trying to acquire. We have a similar issue when using our SPPs to acquire. As long as your switching works, that's all that's important for now
- Sparkz0629
Thanks so much for all the info guys, greatly appreciated
Ahhh, i see... i got a bit paranoid, and thought maybe VW had flashed my car back to stock...
Thanks Shaun
Rabbit222 wrote:hey guys,
Thanks Shaun
- Sparkz0629
I'm gonna be chucking some NF in when i drive down to Durbs... really keen to see the difference... ha ha hachrispribs1 wrote:Sparkz0629 wrote:Hey Chrischrispribs1 wrote:Hey Dex
Nah, no luck yet...
