Event: Panic's Dyno Day!
Date: 14 August 2011
Venue: Petit Airfield, Benoni (Panic's dyno)
Address: Vermeulen St, Benoni, East Rand.
Time: 8.00 am – 4.00pm
Cost: R120 all cars – The idea is to save the dyno…
Food: Mrs Panic will be selling boerie rolls and cool drinks.Bring & Braai - There will also be a lit braai available. Please bring your own meat to braai yourself if you wish.
Queue:
There be a numbered queuing system on a first come first served basis. This means that you will be assigned a number when you enter and will only need to bring your car to the dyno area when called according to the number you have.
Maps and driving directions:
On the N12 you'll take the springs/putfontein exit and go left. just follow that road without turning off. You'll get a stpstreeet and on the right there will be a scrapyard that has a 'helicopter' on a pole - over that - about a km down the road you'll see a cop shop and the first street left after the cop shop is the left turn into Vermeulen road. About 4 km down the road you'll see the airfield on the left.
Directions from the other side:
OK whether you come from PTA or JHB get onto the R21 highway. If you come from The airport side then take the pomona offramp and if you come from PTA then take the R23/Benoni turnoff. If you miss the one - just go off at the next one form either side. At the first junction form both side the direction are the same from there. Look for the engen garage either ahead or on your left and follow the road direction that the garage is on.
GPS Location:
In WGS 84 - Full decimal format S26.08139 E28.38944
or hdddmm.mmm format S26 04.884 E28 23.366
or hour/min/sec format S26 04 53.0 E28 23 22.0
