Event: Drag Day
Date: 2nd October 2010
Venue: ODI
Address: TBA
Time: 08:00 - 16:00
Cost:
VWCSA Members - R150
Non-VWCSA Members - R200
Classes:
- A - 2.0 and above;
B - 1.7 to 2.0;
C - Below 1.7;
FI - Forced Induction;
TDi - Turbo Diesel;
M - Club Member (Non Volkswagen);
O - Open (Non-club Members).
NB...Long pants and long sleeve shirt, closed shoes and helmet are required if you intend taking part. Safety is of top priority
Check back here for more details...
Directions to ODI
Road Map:
From Johannesburg
Take the N1 (Ben Schoeman Highway) to Pretoria. This will become Potgieter Street with C-Max Prison on your left. Proceed down Potgieter Street until you get Church Street. Turn left into Church Street and continue until you get to DF Malan Drive. Turn right into DF Malan Drive and go straight until you get the PPC cement factory on your left. Proceed past until you get Makro on your left. Just after Makro you will get a turnoff that says Mabopane. Turn left onto this road – called Mapopane free-way.
Pass one turnoff until the road makes a 270 degree turn. Proceed over the mountain. Pass first turnoff and cross over N4 pass Roslin turn off.
Take the M20 Hebron turnoff. (7.7 KM from N4 brigbe) turn left and go straight. Be on the lookout for the Morula Sun boards. Proceed straight on until you get the Morula Sun board approximately 10.3 KM to 4way stop MABOPANE GARANKUA. Continue straight over 4way stop for approximately 6.2 KM finding thatch roofs on left and a Liquor store on your right. Across the road is a road that turns left (sign board to ODI RACEWAY). Turn left and follow this road. This will lead you to the track entrance.
Alternative Route
Travel on N1 towards Petersburg. Take N4 split just after Zambezi turnoff. Follow through tollgate. Take 4TH turnoff R80 SHOSHANGUVE left, road makes a complete 270 degree turn. Travel in a northerly direction for 7.7 KM. Precede pass ROSSLYIN turnoff till you see Marula Sun boards take off ramp HEBRON and turn left. Go straight for aprocsimitly 10.3 KM until you find the board marked Marula Sun. There will now be a 4 way crossing MABOPANE GARANKUA set Speedo to zero and go across the 4way stop for 6.2 KM. You will pass thatch roofs on your left and a Liquor store on your right. AT the sign board (ODI RACEWAY). Turn left and follow this road. This will lead you to the track entrance.
