Mythbusters.
PoLonY
Car Model: A8
Membership No: 1997
Re: Mythbusters.
Post by PoLonY »
BlueBlob wrote:Not going to sort out the quoting, but let me answer a few of the questions.
4. Lowering a car might very well increase the top speed. As will tucking away exhausts that hang out, etc.
very true, flat floor pan is the sh!t, look at the bottom of the GTR, Ferrari's etc
is developing a car's down force worthwhile for drag racing considering the speeds one can get to, to help with traction??
or is mainly for track racing?
Re: Mythbusters.
A drag car needs the traction most off the line for launch - Unless you have a huge fan somewhere there is not much airflow to create downforce at that stage. But yes - there are lot of drag cars that use aerodynamic downforce effects at high speed. As a matter of fact all the topfuel dragsters run a wing at the back and it's not there just to finish the look of the rail.
PoLonY
Car Model: A8
Membership No: 1997
Re: Mythbusters.
Post by PoLonY »
panic-mechanic wrote:A drag car needs the traction most off the line for launch - Unless you have a huge fan somewhere there is not much airflow to create downforce at that stage. But yes - there are lot of drag cars that use aerodynamic downforce effects at high speed. As a matter of fact all the topfuel dragsters run a wing at the back and it's not there just to finish the look of the rail.
thought as much, but how come very few of the hatch guys look at changing the rear shape of their cars?they all change the nose of the citi golfs, but do nothing to the back end?
Re: Mythbusters.
depending on the rules of the class you run in you might not be allowed to do that...
rzr
Car Make: VW , DAIHATSU
Car Model: MK3 2.0l16v , 0.9l,6V
Re: Mythbusters.20v vs 16v
Post by rzr »
20v vs 16v
was told by a certain drag racer that the improved airflow of 20vhead vs 16v head and rev abilty , will give you quicker quarter mile because you are still making power higher up in the rev range than 16v. how true is this? will your drag time be quicker by a large margin by using 20v compared to 16v.or is it a waste of time.
its not how u stand by ur car its how u race ur car
BlueBlob
Post by BlueBlob »
rzr wrote:20v vs 16v
Well, 20V can and will make more horsepower than 16V, which will make for a faster drag car. This is a fact.
BUT. Cost is an issue.
The guys in the US almost exclusively use 20V's in drag cars, and most of them make close on 800 to 1000hp. But the cost of those motors will make your eyes water. We're talking like $20k and more.
Not really an option here.
iceblue
Car Model: MK4 GTi
Re: Mythbusters.
Post by iceblue »
:hijack:
Scatman wrote:Yes you get Cd(diameter), Cl(length) and the Cf(friction force)...
You sure about this? I thought Cd stood for Coefficient of Drag, and assumed Cl would be coeff of lift.
My other car's a french maid with a large derriere.
Scatman
Registered for: 16 years 10 months
Car Model: 320d Msport
Membership No: 1773
Re: Mythbusters.
Post by Scatman »
iceblue wrote::hijack:
My sister's boyfriend is a final-year mechanical engineering student, and I just quoted what he told me :lol:
Here's the info for us regular people:
http://en.wikipedia.org/wiki/Drag_coefficient
Wiki FTW :grin: :hi:
2008 BMW 320d Msport Auto
2006 Audi A3 2.0T
2006 BMW E90 330d Manual
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
pboy
Re: Mythbusters.
Post by pboy »
20v vs. 16v
In my opinion ( and i'm referring to a vw 16v head vs a vw 20v head here ): if u look at the head, the 4 valve arrangement covers more surface area of the head than the 5 valve per cylinder setup.
like : 00
00
leaves just the measely "+" or metal showing in between the valves. ( i think its called quench pads surface area )
whereas the : 000
00
leaves a bit more metal showing around the valves in addition to the "+" of metal of the 4 valve setup.
to me this means that the 4 valves actually provide a greater flow in and out of the head than the 5 valves setup.
and also that the 4 valve setup allows u to go for bigger valves, than the limited design of the 5 valve setup.
yamaha for one have reverted back to the 16v setup on their motors.
even the runx rsi head they develped for toyota trumped their "glorious" 4age 20v head with reverting back to a 16v setup.
surely there must be some science in it??
and also in reference to the s2000 rally cars and their heads having "ALOT" of work...there is only so much u CAN do with a head, not just bigger valves now, and besides port and flow etc: i've seen swirl, port shape, multiple angle valve jobs quench pad work watnot done for honda heads locally for not as much money as some of us are thinking it can cost..
anthony taylor doing his thing for R3k per 16v head..is just one of them..
so for me expensive head jobs having hellelujah tricks worthy of a select few who can afford the arm and a leg to do it are a myth..
my 2cents..
and yes about 20v vs. 16v. somehow i still believe in 16v until scientifically proven otherwise ( not sbjectively like the yanks are using it watnot.... )!myth!
BlueBlob
Re: Mythbusters.
Post by BlueBlob »
pboy wrote:20v vs. 16v
I get what you're saying about the valve arrangement, but the simple fact is that 20V flows better.
VW went back to 16V because of FSI. There's no space for the injector on a 20V head.
Abnormal
Registered for: 21 years 2 months
Membership No: 848
Re: Mythbusters.
Post by Abnormal »
Yip looks like the 20v flows better than the 16v.
http://forums.vwvortex.com/showthread.php?1674618/page1
\Oo) \ _w_ / (oO/
pboy
Re: Mythbusters.
Post by pboy »
nerville- shot for the link man!
but its LOOOOooong as my.... :-)
wys me the bits where they show the flowrate in cfm's or something..not disputing anything man, just reiterating that i'm looking at the science behind it to back it up!
also: I understand the bit about there being no place for the injector on fsi.
thats a no brainer man!
thanks chaps!
Abnormal
Membership No: 848
Re: Mythbusters.
Post by Abnormal »
pboy wrote:nerville- shot for the link man!
thanks chaps!
check page 4
\Oo) \ _w_ / (oO/
BatteryWorldPtaEast
Registered for: 17 years 10 months
Car Model: Polo TDI Sportline
Membership No: 1572
Re: Mythbusters.
Post by BatteryWorldPtaEast »
Have anybody discussed the Cold Air Induction yet ?
K&N sells these ,what do think about it ? Does it realy work ?
Daily drive : Polo TDI Sportline 180 Hp 349 Nm ATW (Trevor's Custom Map) At Night Dyno
Wife's : 1.9 Tdi Touran
Son's : Cross Polo 1.6 Tdi
Abnormal
Membership No: 848
Re: Mythbusters.
Post by Abnormal »
DieselTorqueTdi wrote:Have anybody discussed the Cold Air Induction yet ?
have you read page 10?
\Oo) \ _w_ / (oO/
BatteryWorldPtaEast
Membership No: 1572
Re: Mythbusters.
Thanks ,read it .
SemiColon
I sparkle in the sunlight
Registered for: 15 years 4 months
Car Make: Volvo
Car Model: S40 T5
Membership No: 1641
Re: Mythbusters.
Post by SemiColon »
Myth
X) Nitrogen in tyres give's you 20% more tyre life
八拾六
zain_c
Registered for: 15 years 5 months
Car Model: 92 MK2 Jetta 3.2 + 82 Caddy
Re: Mythbusters.
Post by zain_c »
interesting thread we have here. :geek:
1992 MK2 Jetta CSi 3.2
1982 MK1 Caddy
2011 4x4 Tuna
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
04 Citi 14.7 s2s Killarney
06 MK5 Golf
92 MK2 2.0 16v GTi Exec
96 MK3 GTS
Kashi
Car Model: 8P A3 2.0 FSI
Re: Mythbusters.
Post by Kashi »
SHAUN wrote:20) 16valves are for people that dont know how to make power with a 8v
Just love this one.
The best car safety device is a rearview mirror with a cop in it!!!
Kashi
Re: Mythbusters.
Post by Kashi »
SemiColon wrote:Myth
the salesman at twt told me that aswell
Monster
Registered for: 16 years 5 months
Re: Mythbusters.
Post by Monster »
Just love this one.
It's funny cause its true!!!!!
BMW k1200RS
Yakuza Racer
Voora Molester
Re: Mythbusters.
Post by Yakuza Racer »
as i understand it, it makes the temp of the tire cooler thus .....ag fokkit , i actually have no idea, i was gonna quote my guy a TwT :bang: :bang: :lol: :lol:
Thupercharged S4
Re: Mythbusters.
RIght so let's look at the nitorgen thing. The air you breathe is 80% nitrogen and 20% oxygen. So they pop a new tyre on a rim - what's inside - yup it's already filled with 80% nitrogen and 20% oxygen - now to fill it 100% with nitrogen they actually have to draw a vacuum or purge the air form inside the tyre. SO now basically they just pump it up further with nitrogen thus basically only diluting the already there oxygen by about a third. We tried it on the race cars for a couple of races. Made absolutely no difference to tyre temps or wear and it was an absolute pain to go somwhere to find a nitrogen fill stattion everytime you wanted to change tyre pressure. So IMHO just another clever money making scheme - how would you know there ain't just normal compressed air in that nitrogen cylinder anyway?.
Yakuza Racer
Voora Molester
Re: Mythbusters.
panic-mechanic wrote:RIght so let's look at the nitorgen thing. The air you breathe is 80% nitrogen and 20% oxygen. So they pop a new tyre on a rim - what's inside - yup it's already filled with 80% nitrogen and 20% oxygen - now to fill it 100% with nitrogen they actually have to draw a vacuum or purge the air form inside the tyre. SO now basically they just pump it up further with nitrogen thus basically only diluting the already there oxygen by about a third. We tried it on the race cars for a couple of races. Made absolutely no difference to tyre temps or wear and it was an absolute pain to go somwhere to find a nitrogen fill stattion everytime you wanted to change tyre pressure. So IMHO just another clever money making scheme - how would you know there ain't just normal compressed air in that nitrogen cylinder anyway?.
so true....
Thupercharged S4
Wit Ark
Car Model: Citi Chico baby dragster
Re: Mythbusters.
Post by Wit Ark »
Refering back to the roof spoiler on the back of a citigolf, what about a wing? I take it this will have a negative effect on top speed.... I am now not refering to those massive japanese wings they use on drift cars or show and shine competitions, just a smallish wing. Is there really any downforce being created when going faster with something as such or just pure drag?
I want a bit more grip on the back of my citigolf dragster as the end really gets loose when going faster than 140km/h, ok granted the suspension are farked and these needs to be looked at first, but back to the innitial poin, will a small wing be worthwhile for lets say faster speed stability/handling and at what speed/drag compromise?
