The 1.8T Dumpvalve Question. READ HERE BEFORE POSTING!!!!
VWMK120
Registered for: 19 years 2 months
Car Model: A3 8L 1.8T, A4 B7 2.0T
Re: The 1.8T Dumpvalve Question. READ HERE BEFORE POSTING!!!!
Post by VWMK120 »
if u choose to, u can programme your car to run without the MAF, there has been a MK4 with Dictator and the guy only installed that so that he could run a BOV on he setup, so either they programme it that the MAF dont have to opperate in the OEM way but still does the basic, or they programme it out completely.
-8L A3 1.8T FRC
-B7 A4 2.0T FRC
Abnormal
Registered for: 21 years 2 months
Membership No: 848
Post by Abnormal »
But Dicktator is stand alone and not a piggy back.
\Oo) \ _w_ / (oO/
VWMK120
Post by VWMK120 »
Ok, i might be wrong then .... :? But what did Jammex run with, he had half dictator and half Revo.....?
-8L A3 1.8T FRC
-B7 A4 2.0T FRC
Abnormal
Membership No: 848
Post by Abnormal »
IIRC he used 1 for fueling and the other for timing or something like that.
\Oo) \ _w_ / (oO/
MK4 GTI 20VT
Registered for: 18 years 5 months
Car Make: No Cage
Car Model: Only 2 Wheels
Post by MK4 GTI 20VT »
Nerville wrote:IIRC he used 1 for fueling and the other for timing or something like that.
Revo for timing and dicktator for fuelling.
I want to ask the guys that did put this kit on their cars, did your cars fuel economy improve or get worse?
The lower you go, the more you break.
grunjhed
Registered for: 17 years 1 month
Post by grunjhed »
Not sure if this has been covered in here or not, but this appears to be a relatively new product. What are peoples opinions:
http://www.esetuning.com/Forge-Motorspo ... -black.htm
http://www.vwvortex.com/artman/publish/ ... 1972.shtml
http://www.forgemotorsport.com/content. ... =FMDVSPLTR
Bos
Car Model: Caddy
Membership No: 1384
Post by Bos »
Yup, its been discussed :)
http://www.bunkerracing.co.za
Golf 1 Track Car
"Dont drive faster than what your gaurdian angel can fly"
necrotone
Post by necrotone »
I'm running a turbosmart fully recirculating DV...
When driving normal, it makes a sort of PSSSSH PSsh Pssh psh noise and when hammering it, it makes one big PSSSSHHHH noise.
Sounds frikken awesome!!!!
2009 Renault Megane F1 R26
EX 2008 Polo GTI (Stolen 12/07/2009 Glenvista)
grunjhed
Post by grunjhed »
That's an impressive list of specs. Would love to hear that baby boost. What bar you running?
necrotone
Post by necrotone »
grunjhed wrote:That's an impressive list of specs. Would love to hear that baby boost. What bar you running?
Thanks man, I'm running 1.4 bar according to the logs.
Naviuk
Registered for: 18 years 7 months
Post by Naviuk »
Hi
I finally got my hands on a Forge DV Splitter. one of the newer ones that has about a 90 / 10 split.
I wanted to know what is the best way to setup one of these DV's, there are about 46 or 48 spring settings on the DV, My car has been re-mapped with EDS software, as far as i'm aware the boost is up there by 1.2 bar, i have never actualy attached a Boost guage but this is what the tuner told me. it's hitting about 153kw @ 4579rpm with 368nm @ 3244rpm.
Is there an easy way to setup the spring correctly or should i rather just hook it up and take a trip to the guy i had it mapped with?
2006 Subaru Impreza WRX STi
EX: 2007 Polo GTI - Sold
63mm Downpipe and Zoorst
FMIC
EX:2001 Polo Playa 1.6i (Trade-in for GTI)
4 into 2 Brospeed Branch
Primaforce S/S Freeflow
K&N Induction
Gotech Mini X Management
EX: 1970 VW Beetle (Sold to go to UK)
VWMK120
Post by VWMK120 »
Im boosting 1.0 bar and mine is set on 24 clicks and is 100% so if u turn yours to about 26-28 clicks it should be fine, when its to tight u gonna hear a funny chirp noise coming from it.
-8L A3 1.8T FRC
-B7 A4 2.0T FRC
Naviuk
Post by Naviuk »
Cool thanks for the info:)
What are the pros and cons of the spring setting. ie: if it's too hard this will happen and if it's too soft this will happen? is it possible if the DV is not setup right you can lose boost?
last dumb question - the vacum pipe - does this feed information back to the ECU? what is it purpose?
FMIC
K&N Induction
