8v Pistons 4mm above the deck
- VWicked
- Car Model: Golf 2 GTi
- Membership No: 1492
Re: 8v Pistons 4mm above the deck
2.3 pistons have 81mm bore
1992 Golf Mk2 GTi R32
2011 Golf Mk6 R
2010 Touareg V6 TDi
2011 Golf Mk6 R
2010 Touareg V6 TDi
- graham savage
- Colonel
- Membership No: 803
What's wrong with boosting auto power pistons? Guy I know make 220WHp on his 8v Xflow 2.0 turbo with auto power pistons no issues? Fueling and timing is good it won't break pistons.Naku786 wrote:Good luck boosting with autopower pistons... might as well gooi some india kings in the block & blow it up now
- Car Make: VW Caddy
- Car Model: MK1
*Mod Edit*Naku786 wrote:Autopower is a cheap replacement to OEM spec pistons, they will work perfectly fine in N/A application but add boost you gonna need some forged items just to be safe, AE nural pistons for egViSheN007 wrote:Y have you had any personal experiences with it to share?Naku786 wrote:Good luck boosting with autopower pistons... might as well gooi some india kings in the block & blow it up now
if the pistons fail, i will come and post here
- Cake Laaitie Killer
- Car Model: Citi 1.9i 8v
ViSheN007 wrote: *Mod Edit*
- Registered for: 22 years 5 months
- Car Model: 2017 Cross Polo 1.2 TSI
Dude, I should give you the number of the mechanic who built my old Audi motor. This is no problem for him to sort out. Just gooi the whole block and pistons onto the decking machine and level those pistons flat!
Ja, it happened.
Ja, it happened.
2017 VW Cross Polo 1.2TSI
2006 VW Citi 1.4 carb
1995 VW Chico 1.3 4-speed
1989 Audi 500 turbo (the end. finally.)
Hi I got the same problem here piston above the deck same situation how was this solved.
