Fuel Pump Relay
- kmg4real
- Car Make: Volkswagen; BMW
- Car Model: CITI 2.0 16VT; E36 323i
- Membership No: 1381
Fuel Pump Relay
I know this has been discussed in many post, yet there hasn't been anyone posting a pic of the above said. Please if you're so kind to take a pic of both the relays behind the fuse panel of a Velociti and post it. I know one is for the fuel pump. This will be of great help to many.
'02 CITI Golf 2l 16VT 243hp 306Nm @0.8 bar on M.R.D. Dyno - Thread url=http://www.vwclub.co.za/forum/viewtopic ... BlaqSmithe
'98 BMW 323i
Ex - '98 Polo Playa 1.6i
Ex - '11 BMW 320d
Ex - '08 BMW 320i Facelift
Ex - '07 Citroen C2 iPlay
Ex - '07 Golf V GTI
Ex - '04 Audi 1.9TDi 6 spd
Ex - '02 CITI Golf 1.4i
'98 BMW 323i
Ex - '11 BMW 320d
Ex - '07 Golf V GTI
FACT: "I use not only the brains I have, but all that I can Borrow." - Einstein
- Car Make: SEAT
- Membership No: 478
Re: Fuel Pump Relay
They are normal 12v, 40Amp, 4-pin relays?kmg4real wrote:I know this has been discussed in many post, yet there hasn't been anyone posting a pic of the above said. Please if you're so kind to take a pic of both the relays behind the fuse panel of a Velociti and post it. I know one is for the fuel pump. This will be of great help to many.
What would you like to see?
'20 SEAT Tarraco XC 1.5 TSi
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'04 Golf MKIV GTi.:R
'99 Citi Golf 2.0i
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
- kmg4real
Re: Fuel Pump Relay
What it looks like, where it is located. and maybe a small explanation of the pins. Shaun, these questions always pops up and I did a search and went through about 8 pages with repeating info, so clearly there's still others who are esperiencing problems wrt this. People don't usually understand the same way, photos always assist to actually see what is being refered to. My apologies if I'm being a neusense. We can maybe make it a stickyMacMan wrote:
'98 BMW 323i
Ex - '11 BMW 320d
Ex - '07 Golf V GTI
'98 BMW 323i
Ex - '11 BMW 320d
Ex - '07 Golf V GTI
- Car Make: SEAT
Re: Fuel Pump Relay
No problem, I was just wondering what kind of information you were looking for. I will see if I have a picture of them somewhere.kmg4real wrote:What it looks like, where it is located. and maybe a small explanation of the pins. Shaun, these questions always pops up and I did a search and went through about 8 pages with repeating info, so clearly there's still others who are esperiencing problems wrt this. People don't usually understand the same way, photos always assist to actually see what is being refered to. My apologies if I'm being a neusense. We can maybe make it a stickyMacMan wrote:
I need to go to a client now, but I will draw a little diagram when I get back.
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
- kmg4real
Re: Fuel Pump Relay
Thanks Shaun, as always you are a Star
'98 BMW 323i
Ex - '11 BMW 320d
Ex - '07 Golf V GTI
'98 BMW 323i
Ex - '11 BMW 320d
Ex - '07 Golf V GTI
- Car Make: SEAT
Re: Fuel Pump Relay
Ok, excuse my MS Paint skillz, but you get the idea.
For those that don't know what a relay is, it is basically an electrically operated switch that can handle a large amount of current, which makes it perfect for controlling things like fuel pumps and headlights.
In the typical operation of a relay, pin 86 is connected to ground (earth), pin 85 is connected to switched +12V (eg. from a headlight switch or ignition switch, etc), pin 30 is connected to permanent +12V (eg. directly from the battery) and pin 87 is connected to the + (positive) wire of the device you want to switch on (fuel pump, headlights, etc.). Then how it works is you turn the switch, which sends +12V to pin 85 on the relay, which excites the coil inside the relay, which closes the switch inside the relay, which joins pin 30 and pin 87 on the relay, which sends +12V from the battery to the fuel pump or headlights, which switches them on.
In the case of the fuel pump relay on an MP9 equipped car, the relay is connected and is operated slightly differently. Pin 86 is connected to pin 25 on the MP9 ECU, pin 85 is connected to permament +12V (eg. directly from the battery), pin 30 is connected to permament +12V (eg. directly from the battery) and pin 87 is connected to the + (positive) wire of the device you want to switch on (fuel pump, headlights, etc.). Then how it works is when you turn the ignition on, the ECU joins pin 25 to ground (earth), which means pin 86 on the relay is now grounded, which means the coil in the relay can now be excited, which closes the switch inside the relay, which joins pin 30 and pin 87 on the relay, which sends +12V from the battery to the fuel pump or headlights, which switches them on.
I hope that helps.
I hope that helps.
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
- kmg4real
Re: Fuel Pump Relay
It certainly helps.
Thanks a mil Shaun.
Administrators, can we stick this?
'98 BMW 323i
Ex - '11 BMW 320d
Ex - '07 Golf V GTI
'98 BMW 323i
Ex - '11 BMW 320d
Ex - '07 Golf V GTI
Re: Fuel Pump Relay
Hi Macman,is this a universal fitting type and will they work in all cars that require a fuelpump relay ?
thanks
thanks
- Car Make: SEAT
Re: Fuel Pump Relay
The 4-pin relay in the diagram is one of the most common ones used in motor vehicles (well the ones I have worked on anyway), so yes I would say it is universal. But obviously you get relays that have the pins in different locations to fit different relay plugs, but they will still function the same way.Grantm wrote:They are normal 12v, 40Amp, 4-pin relays?
thanks
Yes the above relay can be used in any car that requires a fuel pump relay.
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
Re: Fuel Pump Relay
Thanks for that reply Macman
- Colonel
- Membership No: 1041
Re: Fuel Pump Relay
wont it be better to run pin 86 off the low pressure oil switch, so that the pumps cuts off when the engine cuts off in the case of a accident etc. Or is there another way around this?
- Car Make: SEAT
Re: Fuel Pump Relay
No I wouldn't connect it to the low pressure oil sensor. The MP9 ECU will stop the fuel pump if the engine stops running and I am sure other management systems will do the same.UDC wrote:wont it be better to run pin 86 off the low pressure oil switch, so that the pumps cuts off when the engine cuts off in the case of a accident etc. Or is there another way around this?
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
- Colonel
Re: Fuel Pump Relay
thanks for clearing that upMacMan wrote:No I wouldn't connect it to the low pressure oil sensor. The MP9 ECU will stop the fuel pump if the engine stops running and I am sure other management systems will do the same.UDC wrote:wont it be better to run pin 86 off the low pressure oil switch, so that the pumps cuts off when the engine cuts off in the case of a accident etc. Or is there another way around this?
- Car Model: Citi Life, 6R Polo TDi
- Membership No: 1202
Re: Fuel Pump Relay
I've got a little problem, the car in question is a mk2 GTi 1989 8v model. The stock FP relay is marked 62 on top, part number 321-906-059-G. Lately started acting up, sometimes the car refuse to start until you remove and refit the relay and its getting hot from time to time. I have cleaned the terminals of the relay and the holder but no change.MacMan wrote:No I wouldn't connect it to the low pressure oil sensor. The MP9 ECU will stop the fuel pump if the engine stops running and I am sure other management systems will do the same.UDC wrote:wont it be better to run pin 86 off the low pressure oil switch, so that the pumps cuts off when the engine cuts off in the case of a accident etc. Or is there another way around this?
No here is the problem, its a 5 pin relay, 4 normal sized terminals and 1 half size terminal. So i went to GW for a new relay and they gave me a normal 4-pin, after a long discussion we found one with a similar pin lay-out (mk3 FP relay) but the car won't start and when you turn the key to acc the rev counter indicates max rpm. After some research on the www i figured out that the FP relay also controls the rev limiter on CIS models and that this little bugger costs 50us$.
Now i need some help, unfortunately my electronic skills dropped me here, i want to make up a relay harness with a normal relay that switches on when you 'crank' the motor but switches the pump off if the motor is not running. is this possible??
Any help would be appreciated.
Thanks in advance.
Citi Life
Polo TDI
Turbo + Lag = gracious head start
Polo TDI
- Registered for: 21 years 11 months
Re: Fuel Pump Relay
The 5 pin relay is for a MP9 setup as far as i know.I used a 4 pin Hella relay (actually two of them)with my Gotech setup.
Only place I could source them was from Mercedes here in CT.
97'chico 1600(Altered) sold but still going strong
"I don't suffer from insanity, I enjoy every minute of it."
- Registered for: 20 years 5 months
Re: Fuel Pump Relay
Hi guys,
I know this probably shouldnt be posted here but I am hoping someone can help me.
I have a 2005 Velociti 1.6i
The problem started sometime yesterday (I havent been fiddling with the car - did a minor service a few days ago)
If I switch on the headlamps when driving or idling the car is fine. As soon as I pull the stalk to activate the inner spots the car switches off or the voltage dips really badly. This resets my clock, trip kms, and radio.
I tried starting up the car with the headlamps switched off ... took out the + terminal on the battery and the car was fine (apparently its an alternator test of sorts)
Now someone mentioned to me that this could be a relay problem, problem with the battery, or the alternator.
If its a relay problem can someone shed light on what relay I should get and how I can change it
Drive it like you stole it !
2005 VW Velociti 1.6 Black Magic
ABUSED
2005 Polo 1.6 Comfortline (Eibach Springs - 54KW 109Nm ATW)
1998 Jetta CSL 1.6i w/AC -sold to the cops
2002 Citi.com Black Magic - tragically written off
1998 Tazz 130 - pawned for the Polo
ABUSED
