Brake capiler rattling
rydogg
Registered for: 17 years
Post by rydogg »
Due to my lowered stance, there have been some recent damages, inculding many rattles throughout my vehicle. One of which is most noticalbe. My brake calipers are rattling when I drive over bumpy roads. I know it's the brakes, coz when I brake the rattle stops.
Is there any specific reason why the pads would move away from the discs so much when the brakes are no longer applied?
......___
..../|_|_\__.......= _|_\__
..|@_|_|@|......|@_|_|@|
Mk1 cabriolet - old schooled!
Newton
Registered for: 21 years 10 months
Re: Brake capiler rattling
Post by Newton »
Hi rydogg, not sure what car you drive but check the anti rattle plates on the calipers. These prevent the rattle on the brakes.
His: 1996 Citi Golf 1.3 ....Under Construction
2006 Ford Ranger 2.5TD
NC23 CBR400RR
Honda TRX 400EX
Her's: VW EOS 2.0 FSi
NC23 CBR400RR
Honda TRX 300EX
liv
Registered for: 19 years
Post by liv »
had the same issue Newton jus mentioned on my .com - check those clips. its most likely the cause... you should be able to move the pad slightly by hand if the clips are out of place.
2001 Polo GTI (6N2)
2016 Audi S4 (B9)
2019 Mercedes Benz B180 AMG (W247)
Post by dood786 »
Check antirattle clips and check if the piston is pushing nicely onto the pad
sibusisotong
Registered for: 1 year 9 months
Post by sibusisotong »
Good day guys I drive a polo 1.2 tsi 2016,I have the same rattling issue on the right front wheel,it's the brake pad I saw it but my mechanic because he doesn't bel8ve in rattling plates he says it's not it's the caliper pins the are worn out.I bought these rattling plates the Sure brake band but most mechanics don't know how to fit them is there anywhere where I can go watch a video or something of how it much look or a picture? I tried Google but I am struggling
Ashveer03
Post by Ashveer03 »
sibusisotong wrote:Good day guys I drive a polo 1.2 tsi 2016,I have the same rattling issue on the right front wheel,it's the brake pad I saw it but my mechanic because he doesn't bel8ve in rattling plates he says it's not it's the caliper pins the are worn out.I bought these rattling plates the Sure brake band but most mechanics don't know how to fit them is there anywhere where I can go watch a video or something of how it much look or a picture? I tried Google but I am struggling
U really need to change Ur mechanic. If it's meant to have those plates, it must have them.
That's still quite a new vehicle for the sliding pins to be worn out. It is meant to have a slight movement.
U basically just remove the brake pads, fit the plates onto the caliper bracket and refit the pads. Simple, most of them can only fit in one way.
Not sure what type pads this car has. Some pads have 3 prongs on the inner and outter pads, if it's that type, it may not use those anti rattle plates because those prongs clip on tight onto the caliper.
sibusisotong
Good evening sorry for the late response it's sorted it was the brake pad on the left.I replaces both pads and the noise went away.
