VW MK7 GTi 2015 CHHB Timing chain kit
AvesshenG
Car Make: Vw, Bmw, Merc
Car Model: 81 Vw Mk1 Cabrio,15 Mk7GTi
Membership No: 3258
Post by AvesshenG »
Howsit Guys ,
I'm looking at doing the timing chain on my VW Mk7 GTi 2015
I want to use OEM parts, tried getting a quote on parts from the local dealership but they weren't able to list everything or didn't want to.
For instance their quote only had two chains when the car has 3 different timing chains ,I could see I wasn't going to get helped.
Is there a specific part number for the full timing chain kit?
That way I can order all parts needed as a kit to ensure we have all parts when we open up to do the job.
Its the NON performance pack so the CHHB engine.
Regards :hug:
mk2-phreak
Registered for: 16 years
Re: VW MK7 GTi 2015 CHHB Timing chain kit
Post by mk2-phreak »
You tried speaking to Goldwagen?
SolomonG
Registered for: 4 years 2 months
Post by SolomonG »
Goldwagen quoted R7110 for the timing chain kit for a 2013 mk7 gti
MacMan
Car Make: SEAT
Car Model: Tarraco XC 1.5 TSi
Membership No: 478
Post by MacMan »
AvesshenG wrote: Sat Jun 24, 2023 1:50 pm Howsit Guys ,
Regards :hug:
If you want to do it properly:
Part Number____Description_____________________________________Size__________Quantity
06K109158A______timing chain____________________________________________________1
06K109158AD_____timing chain____________________________________________________1
06H109467AR_____chain tensioner_________________________________________________1
06K109467P______chain tensioner_________________________________________________1
D 154103A1______sealant_______________________________________100G_____________1
06H109469AQ_____slide rail______________________________________________________1
06K109469N______slide rail______________________________________________________1
06H109469AH_____slide rail______________________________________________________1
06K109469M______slide rail______________________________________________________1
06H109509P______slide rail_______________________________________________________1
06H109509Q______slide rail_______________________________________________________1
N 10765401______Hexagon socket flat head bolt___________________M6X35_____________2
N 10156206______Oval hexagon socket head bolt___________________M6X30____________4
06K115225C______Drive chain_____________________________________________________1
N 10706901______Hex collared bolt______________________________M10X55___________1
N 91029602______double stud with hexagon drive__________________M10X55/M6X12_____1
N 91204001______Hexagon bolt__________________________________M8X50____________1
N 10552404______Hex collared bolt______________________________M12X1,5X70________2
N 10701501______Socket head bolt with inner multipoint head_______M10X65___________3
06K103583_______Seal___________________________________________________________2
06K103483_______Seal___________________________________________________________1
D 174003M2______Silicone sealant________________________________80ml_____________1
06K109210AF_____timing case_____________________________________________________1
D 176501A1______Silicon sealant_________________________________50ml______________1
N 91096702______Oval hexagon socket head bolt___________________M6X16____________15
N 91232801______Socket head bolt with inner multipoint head_______M6X52_____________6
'20 SEAT Tarraco XC 1.5 TSi
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'04 Golf MKIV GTi.:R
'99 Citi Golf 2.0i
AvesshenG
Membership No: 3258
Post by AvesshenG »
Thank you for the assistance, Timing chain has been done a few months ago
