7R Motor Needed
- Black&White
- Car Model: 7R
- Membership No: 1863
7R Motor Needed
Howzit all,
Been a second.
Where can I get a "untouched" used 2015 7R motor.
Long story short, oil pump failure = motor failure.
Your assistance would GREATLY be appreciated.
Kind Regards
Martin
Been a second.
Kind Regards
Martin
'15 Golf 7R
'13 6R CrossPolo TDI (Sold)
Polo 2.Slow (Sold)
'03 citi life 1.6 ( stolen & retrieved then sold)
'86 mk1 2door CTI (sold)
Re: 7R Motor Needed
Looking for gold there.
Used motor is very likely to be very "touched".
Best option would be a rebuild. It will be expensive, but likely to have better results than a used motor.
- kingr
- Car Make: VW, Mini, Slowyota
- Car Model: Mk1 2 Door, Hilux D/C
- Membership No: 3337
Re: 7R Motor Needed
I second this option. You should be able build a forged engine for under R100k.missioner wrote:Looking for gold there.
Kurt #3337
- 10" Mx5 NC2 (main daily)
Re: 7R Motor Needed
Less than that. Waay less than a R100k.kingr wrote:I second this option. You should be able build a forged engine for under R100k.missioner wrote:Looking for gold there.
It's actually cheaper to build the forged motor than to return it to stock.
Re: 7R Motor Needed
Depending on how bad it all is and what parts are used, I estimate between R45000 and R60000, engineering, parts and labour included.
- amstel18
- Car Model: Tiguan Allspace
Re: 7R Motor Needed
You forgot the cost of a big turbo
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
Re: 7R Motor Needed
BT isn't necessary at this point, but the forged motor does leave the door open for further mods and moar powah! later.
Initially it just gets it to be sturdy and reliable.
- kingr
Re: 7R Motor Needed
OP have you opened your engine to inspect the damage?
Kurt #3337
- Neuk
- Treasurer
- Registered for: 19 years 7 months
- Membership No: 806
Re: 7R Motor Needed
If you decide to go for a forged rebuild, chat to @JaredS at JS Worx.
- Black&White
- Car Model: 7R
Re: 7R Motor Needed
Sorry guys, missed the notifications for this.
Def considering to Forge the motor, but currently estimate is around 80K. Car was with QT Performance while I went through the ombudsman ordeal.
I collected the car from him just so that its not in his way. Some of the part did come home & some did not. So ill prob build the motor at his shop.
Crank got some damage.
Oilpump gone
Big End bearings
Conrod nr4
Piston nr4
Why Im looking for the motor is, its still going to be a while before I can save up the remaining money for the build (been 9 months without my car)
But im seriously considering just Building the motor & then its good for MOAR POWAH. hahahahaha
'15 Golf 7R
Polo 2.Slow (Sold)
- Black&White
- Car Model: 7R
Re: 7R Motor Needed
Will he be able to sort me out with just the parts maybe?
'15 Golf 7R
Polo 2.Slow (Sold)
Re: 7R Motor Needed
VolkSpares for Wossner pistons and rods.
Best performing and fitting pistons for this motor.
FYI OEM pistons are R16000 for a set. Wossner are R13500 at my last pricing. Similar story with most of the other parts. Goldwagen can help you with most of the rest of the parts, also look at Alert engine spares.
Re: 7R Motor Needed
I saw a used CDN engine on FB marketplace this morning, dunno if it's the same as yours.
- Neuk
- Treasurer
Re: 7R Motor Needed
I am sure that he can, he sources both locally and overseas for various R, S3, RS3, Subaru, Toyota, etc. forged rebuilds. Customers even crate ship their engines or transport their entire cars from all over SA for engine rebuilds.Black&White wrote: ↑Fri Aug 06, 2021 2:06 pmWill he be able to sort me out with just the parts maybe?
- kingr
Re: 7R Motor Needed
sounds like the guy you should be dealing with.Neuk wrote: ↑Tue Aug 10, 2021 10:40 amI am sure that he can, he sources both locally and overseas for various R, S3, RS3, Subaru, Toyota, etc. forged rebuilds. Customers even crate ship their engines or transport their entire cars from all over SA for engine rebuilds.Black&White wrote: ↑Fri Aug 06, 2021 2:06 pmWill he be able to sort me out with just the parts maybe?
Kurt #3337
- Neuk
- Treasurer
Re: 7R Motor Needed
Jared is great, I have known him since I joined the VWCSA back in the mid 2000's, he helped me with a lot of cars over the years and will be doing my Touareg brakes this week hopefully despite being quite busy at the moment. You can check his Facebook page out...kingr wrote: ↑Tue Aug 10, 2021 10:44 amsounds like the guy you should be dealing with.Neuk wrote: ↑Tue Aug 10, 2021 10:40 amI am sure that he can, he sources both locally and overseas for various R, S3, RS3, Subaru, Toyota, etc. forged rebuilds. Customers even crate ship their engines or transport their entire cars from all over SA for engine rebuilds.Black&White wrote: ↑Fri Aug 06, 2021 2:06 pmWill he be able to sort me out with just the parts maybe?
https://www.facebook.com/JSWORXSA/
Or his Instagram...
https://www.instagram.com/jsworx/?hl=en
- Black&White
- Car Model: 7R
Re: 7R Motor Needed
Thanks oom.Neuk wrote: ↑Tue Aug 10, 2021 10:40 amI am sure that he can, he sources both locally and overseas for various R, S3, RS3, Subaru, Toyota, etc. forged rebuilds. Customers even crate ship their engines or transport their entire cars from all over SA for engine rebuilds.Black&White wrote: ↑Fri Aug 06, 2021 2:06 pmWill he be able to sort me out with just the parts maybe?
Just sent him a msg.
'15 Golf 7R
Polo 2.Slow (Sold)
- Neuk
- Treasurer
Re: 7R Motor Needed
PleasureBlack&White wrote: ↑Wed Aug 11, 2021 6:10 pmThanks oom.Neuk wrote: ↑Tue Aug 10, 2021 10:40 amI am sure that he can, he sources both locally and overseas for various R, S3, RS3, Subaru, Toyota, etc. forged rebuilds. Customers even crate ship their engines or transport their entire cars from all over SA for engine rebuilds.Black&White wrote: ↑Fri Aug 06, 2021 2:06 pmWill he be able to sort me out with just the parts maybe?
