2l 16v throttles
Re: 2l 16v throttles
My healthiest vr6 3.1 wirh hea dwork and cams only made 168 hp. In full vr form a citi with a 130 hp abf will still give it a hiding.
syndicate racing
Post by syndicate racing »
mojo786 wrote:+12345
ABF+citi/mk1+deben= :evil:
155whp stock standard my ABF makes here so get a ABF then you have the perfect platform to work with...
And you have the option of sending your head to me aswell.... Lmao i waiting for it.
syndicate racing
CALVIN1 wrote:Howzit guys iv tried finding posts on this and have had no luck, so wanted to know wats the best way to build a 2l 16v on throttles from scratch.like which bottom end do I use with wat head abf or 9a just wanna have a quick N\A mk1 for my weekend use and now and then during the week
All help will be appreciated
I would go long block , 20v large port head, lighten the bottom, and you revving
Iike a bat out of hell with wicked na power.
mojo786
Car Make: Vw+SEAT
Car Model: VeLo+Cupra
Post by mojo786 »
:driving: will be doing as soon as soon as you BB me the damage unless its on the house :wink: :hurray: :grin:
Velo-ABF-ride-thread
2.0 16v ABF - MP9/ Per4mance Custom Tuned-(0837860345)
57mm F/F
Custom ratio Bolted diff Gearbox
CrossDrilled VR6 stoppers!
JOM coilovers
A.R.B
Webasto tilt n slide sunroof
.:R -Line boot spoiler
07 SEAT IBiza CUPRA TDi
Allard EGR delete
BMC flatbed filter
dp/FullZorst
Sw
Mopower.abf@gmail.com
mojo786
Car Make: Vw+SEAT
Post by mojo786 »
Bringing my car to Durban for Dubrun, can't wait to see what she is like at the coast! :evil: :evil: :evil:
Could you suggest some dyno's in Durban for me to comapre (I know it is not going to give me accurate figures as it is not the same dyno I got my car dyno'ed here in JHB).
Experience performance on Pine str durban central,Speed Shop Bayhead road or even ODR on Umbilo road..I'll pm you my number so when your here we can hook up and I'll take you.
57mm F/F
JOM coilovers
A.R.B
Allard EGR delete
BMC flatbed filter
dp/FullZorst
Sw
vdub caddy
Ian F's special snugglebunny
Car Model: Caddy
Membership No: 1548
Post by vdub caddy »
Pm'd you back.
Shot bud, will see you when Dubrun comes around.
Q_Gopal
Registered for: 9 years 1 month
Car Model: 1989 Mk1 Abf Single Throttle
Post by Q_Gopal »
So guys my apologies for stealing this thread...I have a 1989 Mk 1 Blue and White Citi-Golf...which needed a new heart...so we dropped in an ABF 2.0 16v...got this guy running with a mechanic friend. Bought the motor as is just did the normal checks...got Nathan from IXS to put in a 421 branch with 57mm exhaust...added a FFZ gearbox to it welded the pin so if the box break the box wont bust into pieces...took the car as is and got it tuned at AUTOPOWER and hit 125.6kw on the Dyno...after some time the car started hunting with the revs...cleaned the throttle and then I decided that I want to go the throttles route...managed to get 20v throttles for her and also a Rowland intake...now I need to know what route should I go when choosing injectors...and is it expensive as I have to sell a kidney for it...and why are there no videos showing how to build one on Youtube...i will appreciate it if someone could show me some light...because i was thinking 550cc top feed injectors
marzbars
Car Model: 1988 Corrado 16V
Membership No: 1316
Post by marzbars »
You are going to need to relcate your alternator, Dave Ingle sells the kit and I believe Delarey Racing Development is also busy with their design.
Car Make: VW, duh...
Car Model: Stuff
Post by Jetta2 »
Q_Gopal wrote: Wed Feb 26, 2025 1:42 pm So guys my apologies for stealing this thread...I have a 1989 Mk 1 Blue and White Citi-Golf...which needed a new heart...so we dropped in an ABF 2.0 16v...got this guy running with a mechanic friend. Bought the motor as is just did the normal checks...got Nathan from IXS to put in a 421 branch with 57mm exhaust...added a FFZ gearbox to it welded the pin so if the box break the box wont bust into pieces...took the car as is and got it tuned at AUTOPOWER and hit 125.6kw on the Dyno...after some time the car started hunting with the revs...cleaned the throttle and then I decided that I want to go the throttles route...managed to get 20v throttles for her and also a Rowland intake...now I need to know what route should I go when choosing injectors...and is it expensive as I have to sell a kidney for it...and why are there no videos showing how to build one on Youtube...i will appreciate it if someone could show me some light...because i was thinking 550cc top feed injectors
Why 550cc injectors?
550's will flow enough to support about 350hp.
Up to 300cc will be more than enough for your aplication.
ABF injectors are 220cc, if I remember correctly and are perfectly fine for your setup.
I had 550cc injectors on my 2.0 8 valve turbo motor and they flowed plenty enough. I actually swopped them out for lower flow injectors to get the tuning right. Unless you plan on going that route, get the smaller injectors.
Higher flowing injectors will not automatically make more power, even if the management is tuned for it, it will make tuning the idling and low speed tuning more difficult, in fact.
2012 Suzuki Hayabusa
2021 Aprilia RS660
Quik-Trix
Membership No: 3004
Post by Quik-Trix »
The stock injectors that come with the 20v throttles are plenty and will handle cams that you throw in later also. Granted all this is on pump fuel.
